Ir para o conteúdo principal
HP Media Center 876x Cooling Fan Replacement
O que você precisa
  1. HP Media Center 876x Cooling Fan Replacement, Side Panel: passo 1, imagem 1 %32 HP Media Center 876x Cooling Fan Replacement, Side Panel: passo 1, imagem 2 %32
    • Remove the two (9 mm) hand screws on the back panel.
  2. HP Media Center 876x Cooling Fan Replacement: passo 2, imagem 1 %32 HP Media Center 876x Cooling Fan Replacement: passo 2, imagem 2 %32 HP Media Center 876x Cooling Fan Replacement: passo 2, imagem 3 %32
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. HP Media Center 876x Cooling Fan Replacement, Cooling Fan: passo 3, imagem 1 %32 HP Media Center 876x Cooling Fan Replacement, Cooling Fan: passo 3, imagem 2 %32
    • Apply great pressure with fingers on the tabs of the fan casing.
    • While applying pressure, pull the casing upwards to remove.
  4. HP Media Center 876x Cooling Fan Replacement: passo 4, imagem 1 %32 HP Media Center 876x Cooling Fan Replacement: passo 4, imagem 2 %32
    • Simultaneously pull the four corner tabs outward.
    • Grab the center of the fan and slide it, smoothly, outward.
  5. HP Media Center 876x Cooling Fan Replacement: passo 5, imagem 1 %32 HP Media Center 876x Cooling Fan Replacement: passo 5, imagem 2 %32
    • Remove the fan completely from its casing.
    • Take care not to damage any plastic parts or wires.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Clemson, Team 6-1, Benson Spring 2014 Membro de Clemson, Team 6-1, Benson Spring 2014
CLEM-BENSON-S14S6G1
Membros da 3
Autoria de 15 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 25
Duração total: 514
