Ir para o conteúdo principal
HP LaserJet P1102w Motherboard Replacement
O que você precisa
  1. HP LaserJet P1102w Motherboard Replacement, Left Side Panel: passo 1, imagem 1 %32 HP LaserJet P1102w Motherboard Replacement, Left Side Panel: passo 1, imagem 2 %32 HP LaserJet P1102w Motherboard Replacement, Left Side Panel: passo 1, imagem 3 %32
    • Flip printer on it's back. Using the plastic spudger, pry off front panel. There will be two main points to focus as shown.
    • Pry carefully to not break any plastic.
  2. HP LaserJet P1102w Motherboard Replacement: passo 2, imagem 1 %32 HP LaserJet P1102w Motherboard Replacement: passo 2, imagem 2 %32
    • Now that the pry points are free lift up the front panel.
  3. HP LaserJet P1102w Motherboard Replacement: passo 3, imagem 1 %32 HP LaserJet P1102w Motherboard Replacement: passo 3, imagem 2 %32
    • Unscrew the #1 Phillips screw 6mm on the back of the printer.
  4. HP LaserJet P1102w Motherboard Replacement: passo 4, imagem 1 %32 HP LaserJet P1102w Motherboard Replacement: passo 4, imagem 2 %32 HP LaserJet P1102w Motherboard Replacement: passo 4, imagem 3 %32
    • Using the plastic spudger, remove the button housing from the top left of printer.
  5. HP LaserJet P1102w Motherboard Replacement: passo 5, imagem 1 %32 HP LaserJet P1102w Motherboard Replacement: passo 5, imagem 2 %32
    • Once the housing is removed, remove the three buttons.
  6. HP LaserJet P1102w Motherboard Replacement: passo 6, imagem 1 %32 HP LaserJet P1102w Motherboard Replacement: passo 6, imagem 2 %32 HP LaserJet P1102w Motherboard Replacement: passo 6, imagem 3 %32
    • Use the plastic spudger to remove the side panel. There are three main prying points as shown.
  7. HP LaserJet P1102w Motherboard Replacement: passo 7, imagem 1 %32 HP LaserJet P1102w Motherboard Replacement: passo 7, imagem 2 %32
    • With all pry points free, remove the side panel.
  8. HP LaserJet P1102w Motherboard Replacement, Motherboard: passo 8, imagem 1 %32 HP LaserJet P1102w Motherboard Replacement, Motherboard: passo 8, imagem 2 %32 HP LaserJet P1102w Motherboard Replacement, Motherboard: passo 8, imagem 3 %32
    • Remove three #1 Phillips 6mm screws with the #1 Phillips screwdriver.
  9. HP LaserJet P1102w Motherboard Replacement: passo 9, imagem 1 %32 HP LaserJet P1102w Motherboard Replacement: passo 9, imagem 2 %32 HP LaserJet P1102w Motherboard Replacement: passo 9, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a pair of blunt nose tweezers, disconnect both ribbon wires.
    • With both ribbon wires removed we can lift the motherboard out of its housing.
    • There is a little black notch holding the motherboard down by the thumb in the final picture.
    • Be careful pulling, as ribbon wires are very fragile.
Conclusão
4 outras pessoas executaram este guia.
Jerome Etten
Membro desde: 10/04/18
709 Reputação
Autoria de 4 guias
Equipe
UW Stout, Team S6-G4, Ogden Fall 2018 Membro de UW Stout, Team S6-G4, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 47
Duração total: 1,863
