Introdução
Replace the formatter in an HP LaserJet 1160 or 1320.
O que você precisa
Pull on the two tabs on the back of the printer to release the left side cover.
Remove the cover by rotating it towards the front of the printer.
Remove 2 screws on the I/O port cover.
Remove 6 screws on the formatter.
Disconnect 3 connectors from the formatter.
Disconnect 2 flat flexible cables from the formatter.
Remove the formatter from the printer.
Um comentário
Additional connector attached to bottom left of board ignored
