Ir para o conteúdo principal
HP HDX 16-1160US DVD Drive Replacement
O que você precisa
  1. HP HDX 16-1160US DVD Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the device over so that the bottom side is facing up and the battery is facing away from you.
  2. HP HDX 16-1160US DVD Drive Replacement: passo 2, imagem 1 %32 HP HDX 16-1160US DVD Drive Replacement: passo 2, imagem 2 %32 HP HDX 16-1160US DVD Drive Replacement: passo 2, imagem 3 %32
    • Locate the slider under the right side of the battery.
    • Using your thumb, slide it all the way to the left until the front of the battery lifts up.
  3. HP HDX 16-1160US DVD Drive Replacement: passo 3, imagem 1 %32
    • With your thumb still holding the slider to the left, use the opposite hand to lift the battery out, removing it from the computer.
  4. HP HDX 16-1160US DVD Drive Replacement, Keyboard: passo 4, imagem 1 %32
    • Remove the three 4mm screws using Phillips #1 screw driver.
    • Remove the four 6mm screws using Phillips #1 screw driver.
    • Remove the two 3mm screws using Phillips #1 screw driver.
  5. HP HDX 16-1160US DVD Drive Replacement: passo 5, imagem 1 %32
    • Using your fingers, pry off the speaker cover.
  6. HP HDX 16-1160US DVD Drive Replacement: passo 6, imagem 1 %32 HP HDX 16-1160US DVD Drive Replacement: passo 6, imagem 2 %32 HP HDX 16-1160US DVD Drive Replacement: passo 6, imagem 3 %32
    • Use the plastic opener to pry up the chrome keyboard cover from the lab top itself. Carefully work around the edges by prying each snap individually.
    • Remove the chrome keyboard cover.
    • Be careful not to pull the chrome cover completely off because there is a black strip connecting it to the laptop itself.
  7. HP HDX 16-1160US DVD Drive Replacement: passo 7, imagem 1 %32 HP HDX 16-1160US DVD Drive Replacement: passo 7, imagem 2 %32 HP HDX 16-1160US DVD Drive Replacement: passo 7, imagem 3 %32
    • Locate and remove the two 4mm screws with the Phillips #1 screw driver.
  8. HP HDX 16-1160US DVD Drive Replacement: passo 8, imagem 1 %32 HP HDX 16-1160US DVD Drive Replacement: passo 8, imagem 2 %32
    • Using your hands, pull the keyboard out.
    • Do not pull completely off because there is a grey strip connecting it to the laptop itself.
  9. HP HDX 16-1160US DVD Drive Replacement: passo 9, imagem 1 %32 HP HDX 16-1160US DVD Drive Replacement: passo 9, imagem 2 %32
    • Lift the black tab using the plastic opening tool.
    • Gently pull the grey strip out, horizontally way from you. This will release the keyboard from the computer.
  10. HP HDX 16-1160US DVD Drive Replacement, DVD Drive: passo 10, imagem 1 %32
    • Use the Phillips #1 Screw Driver to unscrew the 5mm screw.
  11. HP HDX 16-1160US DVD Drive Replacement: passo 11, imagem 1 %32
    • Flip over the device so that the bottom side is facing up.
    • Use the Phillips #1 Screw Driver to unscrew the 7mm screw near the center of the device.
  12. HP HDX 16-1160US DVD Drive Replacement: passo 12, imagem 1 %32
    • Push down and pull out the DVD on the left side of the device.
Conclusão
3 outras pessoas executaram este guia.
Marshall Reid
Membro desde: 04/14/14
527 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 12-38, Maness Spring 2014 Membro de Cal Poly, Team 12-38, Maness Spring 2014
CPSU-MANESS-S14S12G38
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 17
Duração total: 1,459
