Ir para o conteúdo principal
HP G71t-400 WiFi Card Replacement
O que você precisa
  1. HP G71t-400 WiFi Card Replacement, WiFi Card: passo 1, imagem 1 %32 HP G71t-400 WiFi Card Replacement, WiFi Card: passo 1, imagem 2 %32 HP G71t-400 WiFi Card Replacement, WiFi Card: passo 1, imagem 3 %32
    • Lay the laptop down so the bottom is facing up.
    • Push the slide button, circled in photo 1, to release the battery.
    • Action in picture 2 shows the direction and release.
    • Tilt the battery back in the direction it popped up in and remove the battery.
    • This ensures there is no power in the system that could potentially short out any components.
  2. HP G71t-400 WiFi Card Replacement: passo 2, imagem 1 %32 HP G71t-400 WiFi Card Replacement: passo 2, imagem 2 %32 HP G71t-400 WiFi Card Replacement: passo 2, imagem 3 %32
    • Remove the only circled screw.
    • Lift and remove the cover exposing the WiFi card.
  3. HP G71t-400 WiFi Card Replacement: passo 3, imagem 1 %32
    • Disconnect the two wires attached. Making note to where each wire was connected for easy install.
    • Extract the WiFi card.
Conclusão
Nicholas Castro
Membro desde: 03/24/19
711 Reputação
Autoria de 6 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 92
