Introdução
The thermal paste is usually replaced in conjunction with the cooling fan. Therefore it is a good idea to replace the thermal paste while the laptop is being disassembled to save time.
O que você precisa
Ferramenta utilizada nesse passo:Anti-Static Wrist Strap$7.95
Ground yourself by either touching an unpainted metal surface or by using the Anti-Static wrist strap.
Turn off the computer and remove the charger from the charging port.
Turn the laptop over and slide the battery release catch to the right. The battery will pop up from its slot. Remove it using your fingers.
Use a Phillips #0 screwdriver to remove the 6mm screw from the top panel.
Gently lift and remove the panel. Use a metal spudger if the it seems set in place.
Gently wipe the thermal paste off of the processor and heatsink using an alcohol pad or damp cloth. Let the components dry for a few minutes.
Apply a pea sized amount of thermal paste to the processor and heatsink. Keep the paste thick to prevent forming air bubbles and reducing thermal performance.
