Ir para o conteúdo principal
HP G62-234DX Wi-Fi Card Replacement
O que você precisa
  1. HP G62-234DX Wi-Fi Card Replacement, Wi-Fi Card: passo 1, imagem 1 %32 HP G62-234DX Wi-Fi Card Replacement, Wi-Fi Card: passo 1, imagem 2 %32 HP G62-234DX Wi-Fi Card Replacement, Wi-Fi Card: passo 1, imagem 3 %32
    • Make sure the computer is turned off and disconnected from a charger.
    • Place your laptop on a clean, flat surface with the bottom facing up.
    • Slide the battery lock to the left.
    • Slide the battery out from the laptop while holding the lock to the left.
    • Remove the battery.
  2. HP G62-234DX Wi-Fi Card Replacement: passo 2, imagem 1 %32 HP G62-234DX Wi-Fi Card Replacement: passo 2, imagem 2 %32 HP G62-234DX Wi-Fi Card Replacement: passo 2, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the three 6.0 mm screws.
    • The screws that are attached to the panel do not need to be removed completely.
    • Remove the back panel to access the Wi-Fi card.
  3. HP G62-234DX Wi-Fi Card Replacement: passo 3, imagem 1 %32 HP G62-234DX Wi-Fi Card Replacement: passo 3, imagem 2 %32 HP G62-234DX Wi-Fi Card Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to disconnect the coaxial cables from the Wi-Fi card.
  4. HP G62-234DX Wi-Fi Card Replacement: passo 4, imagem 1 %32 HP G62-234DX Wi-Fi Card Replacement: passo 4, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the 3.0 mm screw from the Wi-Fi card.
    • When the screw is removed the card will pop up at a 45-degree angle.
  5. HP G62-234DX Wi-Fi Card Replacement: passo 5, imagem 1 %32 HP G62-234DX Wi-Fi Card Replacement: passo 5, imagem 2 %32 HP G62-234DX Wi-Fi Card Replacement: passo 5, imagem 3 %32
    • Remove the Wi-Fi card by sliding it out from the socket.
Conclusão
To reassemble your device, follow these instructions in reverse order. Make sure to be careful when attaching the wires back into the Wi-Fi card, they can be very fragile.
Uma outra pessoa concluiu este guia.
Kate Ferland
Membro desde: 11/01/23
836 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 1-1, Petersen Fall 2023 Membro de UMass Dartmouth, Team 1-1, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 138
