Ir para o conteúdo principal
HP G62-234DX Screen Replacement
O que você precisa
  1. HP G62-234DX Screen Replacement, Screen: passo 1, imagem 1 %32 HP G62-234DX Screen Replacement, Screen: passo 1, imagem 2 %32 HP G62-234DX Screen Replacement, Screen: passo 1, imagem 3 %32
    • Make sure the computer is turned off and disconnected from a charger.
    • Place your laptop on a clean, flat surface with the bottom facing up.
    • Slide the battery lock to the left.
    • Slide the battery out from the laptop while holding the lock to the left.
    • Remove the battery.
  2. HP G62-234DX Screen Replacement: passo 2, imagem 1 %32 HP G62-234DX Screen Replacement: passo 2, imagem 2 %32 HP G62-234DX Screen Replacement: passo 2, imagem 3 %32
    • Flip over the laptop and open the laptop.
    • Using a spudger and opening picks, loosen the screen bezel (outer frame).
    • Start from one side of the bezel and work your way around to the other side.
  3. HP G62-234DX Screen Replacement: passo 3, imagem 1 %32 HP G62-234DX Screen Replacement: passo 3, imagem 2 %32 HP G62-234DX Screen Replacement: passo 3, imagem 3 %32
    • Lift the screen bezel with your fingers to reveal the screen unit.
  4. HP G62-234DX Screen Replacement: passo 4, imagem 1 %32 HP G62-234DX Screen Replacement: passo 4, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove one 4.0 mm screw on the left and right hinges.
    • Lift the hinges with your fingers.
  5. HP G62-234DX Screen Replacement: passo 5, imagem 1 %32 HP G62-234DX Screen Replacement: passo 5, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the two 3.0 mm screws on the top of the display.
  6. HP G62-234DX Screen Replacement: passo 6, imagem 1 %32 HP G62-234DX Screen Replacement: passo 6, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove a total of four 3.0 mm screws along the edge of both sides of the screen.
  7. HP G62-234DX Screen Replacement: passo 7, imagem 1 %32 HP G62-234DX Screen Replacement: passo 7, imagem 2 %32 HP G62-234DX Screen Replacement: passo 7, imagem 3 %32
    • Carefully loosen the adhesive under the screen unit using your spudger.
    • Pull off the screen unit using your fingers.
    • The screen is still connected by the display cable.
  8. HP G62-234DX Screen Replacement: passo 8, imagem 1 %32 HP G62-234DX Screen Replacement: passo 8, imagem 2 %32 HP G62-234DX Screen Replacement: passo 8, imagem 3 %32
    • To disconnect the display cable connector, gently push the tip of a spudger under the clip. Then, swing the clip over to the other side of the socket, so that it lays flat against the cable.
    • Lift the protective film slightly and, holding the clip and cable together, gently pull in the direction of the cable to remove the connector from its socket.
    • Safely remove the screen.
Conclusão
Uma outra pessoa concluiu este guia.
Kate Ferland
Membro desde: 11/01/23
836 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 1-1, Petersen Fall 2023 Membro de UMass Dartmouth, Team 1-1, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 153
