Introdução
This guide will explain the process of replacing the hard drive in the HP G62-234DX laptop.
Before beginning the repair, power down your device and unplug it from the charger. It is also recommended to remove the battery.
*Our device did not include a Hard Drive so this instruction is mimed.
O que você precisa
Use a Phillips #0 screwdriver to remove the two screws securing the hard drive panel on the back of the laptop.
Use a spudger to remove hard drive panel and carefully lift it up and out.
