Ir para o conteúdo principal
HP G62-234DX Hard Drive Replacement
O que você precisa
  1. HP G62-234DX Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the computer is turned off, disconnected from the charger, and on a steady surface.
    • Unlock the battery by sliding the button just below it, to the left.
  2. HP G62-234DX Hard Drive Replacement: passo 2, imagem 1 %32
    • While pushing the lock button to the unlock position, slide the battery out and away from the laptop.
    • When sliding the new battery back into the socket, you'll know it's secure when you hear a click.
  3. HP G62-234DX Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 HP G62-234DX Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32 HP G62-234DX Hard Drive Replacement, Hard Drive: passo 3, imagem 3 %32
    • It Is recommended to remove the RAM panel for easier access when removing the hard drive panel.
    • Use a Phillips #0 screwdriver to remove the two screws securing the hard drive panel on the back of the laptop.
    • Use a spudger to remove hard drive panel and carefully lift it up and out.
  4. HP G62-234DX Hard Drive Replacement: passo 4, imagem 1 %32
    • Pull the hard drive from the SATA connector to remove the hard drive from the laptop.
Conclusão
Cameron Popillo
Membro desde: 03/20/23
337 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 5-1, Ramos Spring 2023 Membro de UMass Dartmouth, Team 5-1, Ramos Spring 2023
UMASSD-RAMOS-S23S5G1
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 98
