Ir para o conteúdo principal
HP G62-223CL Hard Drive Replacement
O que você precisa
  1. HP G62-223CL Hard Drive Replacement, Battery Removal: passo 1, imagem 1 %32 HP G62-223CL Hard Drive Replacement, Battery Removal: passo 1, imagem 2 %32
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
  2. HP G62-223CL Hard Drive Replacement: passo 2, imagem 1 %32
    • Carefully remove the battery from its compartment.
  3. HP G62-223CL Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 HP G62-223CL Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32
    • Locate the two Phillips head retaining screws which secure the hard drive compartment.
    • Use a Phillips #0 screwdriver to loosen the retaining screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
  4. HP G62-223CL Hard Drive Replacement: passo 4, imagem 1 %32
    • Locate the three 6 mm Phillips head screws for the hard drive.
    • Use a Phillips #0 screwdriver to remove the screws.
  5. HP G62-223CL Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove the hard drive from the compartment.
    • Pull the connector cable from the end of the hard drive.
  6. HP G62-223CL Hard Drive Replacement: passo 6, imagem 1 %32
    • Locate the two 6 mm Phillips head screws on each side of the hard drive.
    • Remove the cover from the hard drive.
Conclusão
Garret Layton
Membro desde: 01/13/15
669 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-4, Sullivan Winter 2015 Membro de USF Tampa, Team 1-4, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 14
Duração total: 2,649
