Ir para o conteúdo principal
HP G62-144DX Keyboard Replacement
O que você precisa
  1. HP G62-144DX Keyboard Replacement, Battery: passo 1, imagem 1 %32 HP G62-144DX Keyboard Replacement, Battery: passo 1, imagem 2 %32
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX Keyboard Replacement, Keyboard: passo 2, imagem 1 %32
    • Remove the 3 Phillips 2.5x5 screws (closest to the battery slot) and the 2 Phillips 2.5x6.5 screws with a Phillips #1 screwdriver.
    • This screws will have a keyboard symbol inscribed next to them.
  3. HP G62-144DX Keyboard Replacement: passo 3, imagem 1 %32 HP G62-144DX Keyboard Replacement: passo 3, imagem 2 %32 HP G62-144DX Keyboard Replacement: passo 3, imagem 3 %32
    • Use the Phillips # 1 screwdriver to unscrew the 2.5x6 Phillips screws holding the L-shaped back panel.
    • Screws should stay in panel, but come free of the laptop body.
    • Gently use a plastic opening tool to remove the panel.
  4. HP G62-144DX Keyboard Replacement: passo 4, imagem 1 %32 HP G62-144DX Keyboard Replacement: passo 4, imagem 2 %32
    • Unscrew the final Phillips 2.5x5 keyboard screw with a Phillips #1 screwdriver.
  5. HP G62-144DX Keyboard Replacement: passo 5, imagem 1 %32 HP G62-144DX Keyboard Replacement: passo 5, imagem 2 %32
    • Flip the laptop so the top is facing up again and open the cover.
    • Use a metal spudger to pry the keyboard up and pull it back.
    • Be sure to pry up the board itself and not an individual key.
    • This process has the risk of breaking keys.
  6. HP G62-144DX Keyboard Replacement: passo 6, imagem 1 %32 HP G62-144DX Keyboard Replacement: passo 6, imagem 2 %32
    • Pull up the latch that connects the keyboard connector the the motherboard.
Conclusão
Cameron Moran
Membro desde: 10/18/17
623 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team S4-G8, Julie Fall 2017 Membro de UMass Dartmouth, Team S4-G8, Julie Fall 2017
UMASSD-JULIE-F17S4G8
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 619
