Ir para o conteúdo principal
HP G62 347NR Keyboard Replacement
O que você precisa
  1. HP G62 347NR Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
    • Turn the device over so the bottom is facing up.
    • Slide the battery release to the left until you hear a click.
    • Once you hear a click, the battery will have been released from the battery compartment.
  2. HP G62 347NR Keyboard Replacement: passo 2, imagem 1 %32
    • Remove the battery, carefully, from the compartment.
  3. HP G62 347NR Keyboard Replacement: passo 3, imagem 1 %32 HP G62 347NR Keyboard Replacement: passo 3, imagem 2 %32
    • Find the hard drive compartment with two Phillips head screws.
    • Use the PH1 screwdriver to loosen and remove both screws.
    • Gently remove the hard drive compartment.
  4. HP G62 347NR Keyboard Replacement: passo 4, imagem 1 %32 HP G62 347NR Keyboard Replacement: passo 4, imagem 2 %32
    • Locate the three Phillips head screws on the compartment with the wifi and keyboard logos.
    • Using the Phillips #1 screwdriver, remove the three screws.
  5. HP G62 347NR Keyboard Replacement: passo 5, imagem 1 %32 HP G62 347NR Keyboard Replacement: passo 5, imagem 2 %32
    • Locate the two keyboard logos on back of the computer.
    • Find the Phillips head screws in the hole next to the logo.
    • Remove the two screws using a Phillips #1 screwdriver.
  6. HP G62 347NR Keyboard Replacement: passo 6, imagem 1 %32 HP G62 347NR Keyboard Replacement: passo 6, imagem 2 %32
    • In the battery compartment, locate the three keyboard logos.
    • Find the Phillips head screws next to each logo.
    • Remove the three screws using the Phillips #1 screwdriver.
  7. HP G62 347NR Keyboard Replacement: passo 7, imagem 1 %32 HP G62 347NR Keyboard Replacement: passo 7, imagem 2 %32
    • Place the plastic opening tool between the keyboard and the motherboard.
    • Gently pry the entire keyboard up and away from the laptop's motherboard.
    • Once you have part of the keyboard separated, run your fingers around the edge of the keyboard to separate the entire thing.
Conclusão
3 outras pessoas executaram este guia.
McKenzi Morris
Membro desde: 10/10/16
511 Reputação
Autoria de 3 guias
Equipe
Texas Tech, Team 6-1, Bennett Fall 2016 Membro de Texas Tech, Team 6-1, Bennett Fall 2016
TTU-BENNETT-F16S6G1
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 2,770
