Ir para o conteúdo principal
HP G62 347NR CD/DVD Drive Replacement
O que você precisa
  1. HP G62 347NR  CD/DVD Drive Replacement, CD/DVD Drive: passo 1, imagem 1 %32
    • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
    • Turn the device over so the bottom is facing up.
    • Slide the battery release to the left until you hear a click.
    • Once you hear a click, the battery will have been released from the battery compartment.
  2. HP G62 347NR  CD/DVD Drive Replacement: passo 2, imagem 1 %32
    • Remove the battery, carefully, from the compartment.
  3. HP G62 347NR  CD/DVD Drive Replacement: passo 3, imagem 1 %32
    • Find the hard drive compartment with two Phillips head screws.
    • Use the PH1 screwdriver to loosen and remove both screws.
    • Gently remove the hard drive compartment.
  4. HP G62 347NR  CD/DVD Drive Replacement: passo 4, imagem 1 %32
    • On the far left of the hard drive compartment, find the Phillips head screw.
    • Remove the Phillips head screw with the PH1 screwdriver.
  5. HP G62 347NR  CD/DVD Drive Replacement: passo 5, imagem 1 %32 HP G62 347NR  CD/DVD Drive Replacement: passo 5, imagem 2 %32
    • Get the plastic opening tool and place it between the laptop and the CD/DVD drive. Place it toward the center of the drive for maximum support.
    • Carefully pry the CD/DVD drive open.
    • Slide the CD/DVD drive out once it is pried open.
Conclusão
McKenzi Morris
Membro desde: 10/10/16
511 Reputação
Autoria de 3 guias
Equipe
Texas Tech, Team 6-1, Bennett Fall 2016 Membro de Texas Tech, Team 6-1, Bennett Fall 2016
TTU-BENNETT-F16S6G1
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 16
Duração total: 542
