Introdução
Failure for the computer to start up and show a constant black screen will likely be an issue concerning the RAM. The tool needed for this process is a Philips Head #0 screwdriver in which you will unscrew two screws on the outside and press on two levers on the inside. After this process is done delicately, the RAM can be removed.
O que você precisa
Quase terminado!
Conclusão
