Ir para o conteúdo principal
HP G60-443CL Battery Replacement
O que você precisa
  1. HP G60-443CL Battery Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop upside down where the headphone and auxiliary jack are facing you.
  2. HP G60-443CL Battery Replacement: passo 2, imagem 1 %32
    • In the top left corner, there is a lever that has a small picture of a battery on it. Slide the lever to the left.
  3. HP G60-443CL Battery Replacement: passo 3, imagem 1 %32
    • Once you have slid the lever to the left, the front part of the battery will be released and you should be able to grab the released part of the battery with your thumb.
  4. HP G60-443CL Battery Replacement: passo 4, imagem 1 %32
    • The battery can then be pulled out of its compartment by hand.
Conclusão
Alora Allen
Membro desde: 11/06/17
101 Reputação
Autoria de 1 guia
Equipe
Baylor, Team S8-G7, Johnson Fall 2017 Membro de Baylor, Team S8-G7, Johnson Fall 2017
BU-JOHNSON-F17S8G7
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 304
