Introdução
Make sure you have completed the keyboard replacement guide and the top cover removal guide.
A broken cooling fan can cause your laptop to overheat. This guide will show you how to correctly replace the cooling fan for your HP Folio 13t-1000.
O que você precisa
Use a PH1 screw head to remove the 16, 6mm screws from the bottom case housing of the laptop.
Place your finger between one of the plastic clamps and the cable and apply a slight leveraging force until the clamp pops up.
Do the same for the second connection.
