Ir para o conteúdo principal
HP Folio 13t-1000 Cooling Fan Replacement
O que você precisa
  1. HP Folio 13t-1000 Cooling Fan Replacement, Keyboard: passo 1, imagem 1 %32 HP Folio 13t-1000 Cooling Fan Replacement, Keyboard: passo 1, imagem 2 %32
    • Use an antistatic wrist wrap, or periodically touch unpainted metal to minimize the risk of damaging the laptop by electrostatic shock.
    • Use a PH1 screw head to remove the 16, 6mm screws from the bottom case housing of the laptop.
  2. HP Folio 13t-1000 Cooling Fan Replacement: passo 2, imagem 1 %32 HP Folio 13t-1000 Cooling Fan Replacement: passo 2, imagem 2 %32 HP Folio 13t-1000 Cooling Fan Replacement: passo 2, imagem 3 %32
    • This step requires unlocking the very fragile plastic clips along the frame; take care not to damage them.
    • Slide the spudger with a twisting motion along the entire perimeter of the laptop until the top cover is separated from the frame of the device.
  3. HP Folio 13t-1000 Cooling Fan Replacement: passo 3, imagem 1 %32
    • Using the flat portion of the plastic spudger, push the corner of the black surface until the first clip unlocks.
    • The top right corner of the keyboard should now be sticking out slightly.
    • Repeat the same process for the top left corner.
  4. HP Folio 13t-1000 Cooling Fan Replacement: passo 4, imagem 1 %32 HP Folio 13t-1000 Cooling Fan Replacement: passo 4, imagem 2 %32
    • Slide the keyboard up and towards the screen just enough to separate the keyboard from the top cover.
  5. HP Folio 13t-1000 Cooling Fan Replacement: passo 5, imagem 1 %32 HP Folio 13t-1000 Cooling Fan Replacement: passo 5, imagem 2 %32 HP Folio 13t-1000 Cooling Fan Replacement: passo 5, imagem 3 %32
    • To unlock the clamps connected to the motherboard, use your fingers or insert the pointed edge of the spudger between the first clamp and the cable.
    • Repeat the same process for the second clamp.
  6. HP Folio 13t-1000 Cooling Fan Replacement: passo 6, imagem 1 %32 HP Folio 13t-1000 Cooling Fan Replacement: passo 6, imagem 2 %32 HP Folio 13t-1000 Cooling Fan Replacement: passo 6, imagem 3 %32
    • Remove the keyboard from the laptop.
  7. HP Folio 13t-1000 Cooling Fan Replacement, Top Hardware Cover: passo 7, imagem 1 %32 HP Folio 13t-1000 Cooling Fan Replacement, Top Hardware Cover: passo 7, imagem 2 %32 HP Folio 13t-1000 Cooling Fan Replacement, Top Hardware Cover: passo 7, imagem 3 %32
    • Place your finger between one of the plastic clamps and the cable and apply a slight leveraging force until the clamp pops up.
    • Do the same for the second connection.
  8. HP Folio 13t-1000 Cooling Fan Replacement: passo 8, imagem 1 %32 HP Folio 13t-1000 Cooling Fan Replacement: passo 8, imagem 2 %32
    • Remove the top hardware cover.
  9. HP Folio 13t-1000 Cooling Fan Replacement, Cooling Fan: passo 9, imagem 1 %32 HP Folio 13t-1000 Cooling Fan Replacement, Cooling Fan: passo 9, imagem 2 %32
    • Use a PH1 screw head to remove the two, 3mm screws.
  10. HP Folio 13t-1000 Cooling Fan Replacement: passo 10, imagem 1 %32 HP Folio 13t-1000 Cooling Fan Replacement: passo 10, imagem 2 %32
    • Remove the connection from the fan to the motherboard by using the nylon spudger or your fingers.
  11. HP Folio 13t-1000 Cooling Fan Replacement: passo 11, imagem 1 %32 HP Folio 13t-1000 Cooling Fan Replacement: passo 11, imagem 2 %32
    • Remove and replace the cooling fan.
Conclusão
Josh Rollins
Membro desde: 09/28/16
131 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-2, Cagle Fall 2016 Membro de USF Tampa, Team 1-2, Cagle Fall 2016
USFT-CAGLE-F16S1G2
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 1,324
