Ir para o conteúdo principal
HP Envy x360 m6-w103dx Speakers Replacement
O que você precisa
  1. HP Envy x360 m6-w103dx Speakers Replacement, Keyboard: passo 1, imagem 1 %32 HP Envy x360 m6-w103dx Speakers Replacement, Keyboard: passo 1, imagem 2 %32
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Speakers Replacement: passo 2, imagem 1 %32 HP Envy x360 m6-w103dx Speakers Replacement: passo 2, imagem 2 %32
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Speakers Replacement: passo 3, imagem 1 %32 HP Envy x360 m6-w103dx Speakers Replacement: passo 3, imagem 2 %32 HP Envy x360 m6-w103dx Speakers Replacement: passo 3, imagem 3 %32
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Speakers Replacement: passo 4, imagem 1 %32 HP Envy x360 m6-w103dx Speakers Replacement: passo 4, imagem 2 %32 HP Envy x360 m6-w103dx Speakers Replacement: passo 4, imagem 3 %32
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
  5. HP Envy x360 m6-w103dx Speakers Replacement, Speakers: passo 5, imagem 1 %32
    • Disconnect the connector on the left speaker by gently pulling on each side of the connector.
    • Do not pull directly on the wires.
  6. HP Envy x360 m6-w103dx Speakers Replacement: passo 6, imagem 1 %32 HP Envy x360 m6-w103dx Speakers Replacement: passo 6, imagem 2 %32
    • Unscrew the three 6mm screws using a #00 Phillips screwdriver, one on the right speaker and two on the left speaker.
  7. HP Envy x360 m6-w103dx Speakers Replacement: passo 7, imagem 1 %32 HP Envy x360 m6-w103dx Speakers Replacement: passo 7, imagem 2 %32 HP Envy x360 m6-w103dx Speakers Replacement: passo 7, imagem 3 %32
    • Remove each speaker one at a time.
    • Carefully remove the wire connecting the two speakers, which is tucked under small plastic hooks on the bottom edge of the device.
Conclusão
Steven Ngo
Membro desde: 10/10/19
927 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S12-G2, Regan Fall 2019 Membro de Cal Poly, Team S12-G2, Regan Fall 2019
CPSU-REGAN-F19S12G2
Membros da 4
Autoria de 23 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 638
