Introdução
This replacement guide is for the keyboard of the HP Envy x360 m6-w103dx. All you need to complete this guide is a plastic opening tool, a #0 Phillips screwdriver, and an anti-static wrist strap.
Wear the anti-static wrist strap and attach it to a metal surface to avoid damaging sensitive electrical components. Make sure the computer is unplugged and powered off before touching any internal parts.
Removing the keyboard is not dangerous and doesn’t require any special technical skills.
O que você precisa
Lift the keyboard until you can see the cables connected to the motherboard.
Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
Detach the keyboard.
Uma outra pessoa concluiu este guia.
