Ir para o conteúdo principal
HP Envy x360 m6-w103dx Daughterboard Replacement
O que você precisa
  1. HP Envy x360 m6-w103dx Daughterboard Replacement, Keyboard: passo 1, imagem 1 %32 HP Envy x360 m6-w103dx Daughterboard Replacement, Keyboard: passo 1, imagem 2 %32
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Daughterboard Replacement: passo 2, imagem 1 %32 HP Envy x360 m6-w103dx Daughterboard Replacement: passo 2, imagem 2 %32
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Daughterboard Replacement: passo 3, imagem 1 %32 HP Envy x360 m6-w103dx Daughterboard Replacement: passo 3, imagem 2 %32 HP Envy x360 m6-w103dx Daughterboard Replacement: passo 3, imagem 3 %32
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Daughterboard Replacement: passo 4, imagem 1 %32 HP Envy x360 m6-w103dx Daughterboard Replacement: passo 4, imagem 2 %32 HP Envy x360 m6-w103dx Daughterboard Replacement: passo 4, imagem 3 %32
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
  5. HP Envy x360 m6-w103dx Daughterboard Replacement, Battery: passo 5, imagem 1 %32 HP Envy x360 m6-w103dx Daughterboard Replacement, Battery: passo 5, imagem 2 %32 HP Envy x360 m6-w103dx Daughterboard Replacement, Battery: passo 5, imagem 3 %32
    • Remove the four 6 mm Phillips #0 screws holding the battery in place.
    • The white arrows on the battery point to where each screw is.
  6. HP Envy x360 m6-w103dx Daughterboard Replacement: passo 6, imagem 1 %32 HP Envy x360 m6-w103dx Daughterboard Replacement: passo 6, imagem 2 %32 HP Envy x360 m6-w103dx Daughterboard Replacement: passo 6, imagem 3 %32
    • Unplug the ribbon cable by flipping up the white tabs on the ZIF connectors and gently sliding the ribbon cables out of their sockets.
    • Unplug the battery connector by grasping the small white tabs on either side of the connector and pulling down towards the battery.
  7. HP Envy x360 m6-w103dx Daughterboard Replacement: passo 7, imagem 1 %32 HP Envy x360 m6-w103dx Daughterboard Replacement: passo 7, imagem 2 %32 HP Envy x360 m6-w103dx Daughterboard Replacement: passo 7, imagem 3 %32
    • Lift out the battery.
    • You may need to peel off the ribbon cable and replace it after installing the new battery if your replacement part doesn't have one already adhered.
  8. HP Envy x360 m6-w103dx Daughterboard Replacement, Daughterboard: passo 8, imagem 1 %32
    • Unscrew the two screws from the daughterboard using a Phillips #0 screwdriver.
  9. HP Envy x360 m6-w103dx Daughterboard Replacement: passo 9, imagem 1 %32
    • Use the plastic opening tool to remove the daughterboard.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 157
