Introdução
This replacement guide is for the daughterboard of the HP Envy x360 m6-w103dx. The daughterboard contains a USB port and SD card slot.
Make sure the computer is unplugged and powered off before touching any internal parts.
Removing the daughterboard is not dangerous and doesn’t require any special technical skills.
O que você precisa
Lift the keyboard until you can see the cables connected to the motherboard.
Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
Detach the keyboard.
Unscrew the two screws from the daughterboard using a Phillips #0 screwdriver.
