Ir para o conteúdo principal
HP Envy x360 m6-w103dx Battery Replacement
O que você precisa
  1. HP Envy x360 m6-w103dx Battery Replacement, Keyboard: passo 1, imagem 1 %32 HP Envy x360 m6-w103dx Battery Replacement, Keyboard: passo 1, imagem 2 %32
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Battery Replacement: passo 2, imagem 1 %32 HP Envy x360 m6-w103dx Battery Replacement: passo 2, imagem 2 %32
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Battery Replacement: passo 3, imagem 1 %32 HP Envy x360 m6-w103dx Battery Replacement: passo 3, imagem 2 %32 HP Envy x360 m6-w103dx Battery Replacement: passo 3, imagem 3 %32
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Battery Replacement: passo 4, imagem 1 %32 HP Envy x360 m6-w103dx Battery Replacement: passo 4, imagem 2 %32 HP Envy x360 m6-w103dx Battery Replacement: passo 4, imagem 3 %32
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
  5. HP Envy x360 m6-w103dx Battery Replacement, Battery: passo 5, imagem 1 %32 HP Envy x360 m6-w103dx Battery Replacement, Battery: passo 5, imagem 2 %32 HP Envy x360 m6-w103dx Battery Replacement, Battery: passo 5, imagem 3 %32
    • Remove the four 6 mm Phillips #0 screws holding the battery in place.
    • The white arrows on the battery point to where each screw is.
  6. HP Envy x360 m6-w103dx Battery Replacement: passo 6, imagem 1 %32 HP Envy x360 m6-w103dx Battery Replacement: passo 6, imagem 2 %32 HP Envy x360 m6-w103dx Battery Replacement: passo 6, imagem 3 %32
    • Unplug the ribbon cable by flipping up the white tabs on the ZIF connectors and gently sliding the ribbon cables out of their sockets.
    • Unplug the battery connector by grasping the small white tabs on either side of the connector and pulling down towards the battery.
  7. HP Envy x360 m6-w103dx Battery Replacement: passo 7, imagem 1 %32 HP Envy x360 m6-w103dx Battery Replacement: passo 7, imagem 2 %32 HP Envy x360 m6-w103dx Battery Replacement: passo 7, imagem 3 %32
    • Lift out the battery.
    • You may need to peel off the ribbon cable and replace it after installing the new battery if your replacement part doesn't have one already adhered.
Conclusão
8 outras pessoas executaram este guia.
Steven Ngo
Membro desde: 10/10/19
927 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S12-G2, Regan Fall 2019 Membro de Cal Poly, Team S12-G2, Regan Fall 2019
CPSU-REGAN-F19S12G2
Membros da 4
Autoria de 23 guias
3 comentários
Thank you Steven for the provided guide, it helped a lot! There are no guides available on the internet particular for the HP Envy x360 m6-w103dx Battery Replacement. And using the IFIXIT tool kit, it was much easier to replace the battery…love these tools. Awesome job!
Charlie - Responder
Thank you, I was able to change the battery successfully, not an easy task with this model of laptop. I would not have been able to do it without your instructions.
Nancy Gaj - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 20
Últimos 30 dias: 145
Duração total: 8,236
