Ir para o conteúdo principal
HP Envy x360 m6-w 101dx Motherboard Replacement
O que você precisa
  1. HP Envy x360 m6-w 101dx Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Lift the keyboard and locate the Motherboard
  2. HP Envy x360 m6-w 101dx Motherboard Replacement: passo 2, imagem 1 %32 HP Envy x360 m6-w 101dx Motherboard Replacement: passo 2, imagem 2 %32
    • Once located, Disconnect all the cables you see connected to the Motherboard.
    • photos indicate disconnecting the CPU, Battery from the motherboard.
  3. HP Envy x360 m6-w 101dx Motherboard Replacement: passo 3, imagem 1 %32 HP Envy x360 m6-w 101dx Motherboard Replacement: passo 3, imagem 2 %32 HP Envy x360 m6-w 101dx Motherboard Replacement: passo 3, imagem 3 %32
    • Continue disconnecting the cables associated with motherboard
    • Photos indicate the SD card, screen and fan have all been disconnected from the motherboard.
  4. HP Envy x360 m6-w 101dx Motherboard Replacement: passo 4, imagem 1 %32
    • Using your Pro tech tool screwdriver #1 remove the 4.5mm phillips screw that connect the motherboard to the laptop, located above the CPU Unit.
  5. HP Envy x360 m6-w 101dx Motherboard Replacement: passo 5, imagem 1 %32
    • Continue unscrewing the highlighted 4.5mm phillips screws in the yellow circles.
    • Gently lift the fan on an angle, this will also lift the Motherboard aswell.
    • Carefully wiggle the fan and motherboard left to right, disconnecting the ports located on the right side of your laptop, you can now remove the motherboard and fan safely.
Conclusão
To reassemble your device, follow these instructions in reverse order,
Ebrihim Tunkara
Membro desde: 02/05/20
1 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 39
Ao todo: 136
