Introdução
This is a guide to replace the RAM in the laptop. You will only need the anti-static wristband for this guide.
O que você precisa
Flip the laptop over to expose the underside.
Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
Ferramenta utilizada nesse passo:Anti-Static Wrist Strap$7.95
Remove the ram’s metal cover with your hand.
