Ir para o conteúdo principal
HP Envy x360 m6-aq103dx Headphone Jack Replacement
O que você precisa
  1. HP Envy x360 m6-aq103dx Headphone Jack Replacement, Bottom Cover: passo 1, imagem 1 %32 HP Envy x360 m6-aq103dx Headphone Jack Replacement, Bottom Cover: passo 1, imagem 2 %32 HP Envy x360 m6-aq103dx Headphone Jack Replacement, Bottom Cover: passo 1, imagem 3 %32
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Headphone Jack Replacement: passo 2, imagem 1 %32
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Headphone Jack Replacement: passo 3, imagem 1 %32
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Headphone Jack Replacement: passo 4, imagem 1 %32 HP Envy x360 m6-aq103dx Headphone Jack Replacement: passo 4, imagem 2 %32 HP Envy x360 m6-aq103dx Headphone Jack Replacement: passo 4, imagem 3 %32
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx Headphone Jack Replacement, Battery: passo 5, imagem 1 %32 HP Envy x360 m6-aq103dx Headphone Jack Replacement, Battery: passo 5, imagem 2 %32
    • Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
  6. HP Envy x360 m6-aq103dx Headphone Jack Replacement: passo 6, imagem 1 %32 HP Envy x360 m6-aq103dx Headphone Jack Replacement: passo 6, imagem 2 %32 HP Envy x360 m6-aq103dx Headphone Jack Replacement: passo 6, imagem 3 %32
    • Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
    • Lift up the port with the tool.
  7. HP Envy x360 m6-aq103dx Headphone Jack Replacement: passo 7, imagem 1 %32 HP Envy x360 m6-aq103dx Headphone Jack Replacement: passo 7, imagem 2 %32 HP Envy x360 m6-aq103dx Headphone Jack Replacement: passo 7, imagem 3 %32
    • Lift the battery out of the laptop with your hands.
  8. HP Envy x360 m6-aq103dx Headphone Jack Replacement, Headphone Jack: passo 8, imagem 1 %32 HP Envy x360 m6-aq103dx Headphone Jack Replacement, Headphone Jack: passo 8, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Make sure you are wearing an anti-static wrist strap.
    • Remove the four screws from the blue board that contains the headphone jack using the Phillips head 1 screwdriver (one 4 mm black screw, one 3 mm black screw, and two 4.5 mm silver screws).
  9. HP Envy x360 m6-aq103dx Headphone Jack Replacement: passo 9, imagem 1 %32 HP Envy x360 m6-aq103dx Headphone Jack Replacement: passo 9, imagem 2 %32 HP Envy x360 m6-aq103dx Headphone Jack Replacement: passo 9, imagem 3 %32
    • Insert the plastic opening tool underneath the connector on the black flexible flat cable with the blue plastic stripe.
    • Lift the opening tool to open the connector.
    • Use your fingers to slide the ribbon cable out of the connector.
  10. HP Envy x360 m6-aq103dx Headphone Jack Replacement: passo 10, imagem 1 %32 HP Envy x360 m6-aq103dx Headphone Jack Replacement: passo 10, imagem 2 %32 HP Envy x360 m6-aq103dx Headphone Jack Replacement: passo 10, imagem 3 %32
    • Hold the left side of the board between your fingers.
    • Lift the edge upwards enough to clear the other components in the way.
    • Be gentle when lifting to avoid breaking the board.
    • Slide and rotate to lift the board out of the designated slot for the board.
    • You may have to wiggle the board back and forth, and up and down, to remove the board.
Conclusão
Uma outra pessoa concluiu este guia.
Jordan Eremeyeff
Membro desde: 10/01/17
597 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S4-G3, Livingston Fall 2017 Membro de Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 1,514
