Ir para o conteúdo principal
HP Envy x360 m6-aq103dx CPU Fan Replacement
O que você precisa
  1. HP Envy x360 m6-aq103dx CPU Fan Replacement, Bottom Cover: passo 1, imagem 1 %32 HP Envy x360 m6-aq103dx CPU Fan Replacement, Bottom Cover: passo 1, imagem 2 %32 HP Envy x360 m6-aq103dx CPU Fan Replacement, Bottom Cover: passo 1, imagem 3 %32
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx CPU Fan Replacement: passo 2, imagem 1 %32
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx CPU Fan Replacement: passo 3, imagem 1 %32
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx CPU Fan Replacement: passo 4, imagem 1 %32 HP Envy x360 m6-aq103dx CPU Fan Replacement: passo 4, imagem 2 %32 HP Envy x360 m6-aq103dx CPU Fan Replacement: passo 4, imagem 3 %32
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx CPU Fan Replacement, CPU Fan: passo 5, imagem 1 %32 HP Envy x360 m6-aq103dx CPU Fan Replacement, CPU Fan: passo 5, imagem 2 %32 HP Envy x360 m6-aq103dx CPU Fan Replacement, CPU Fan: passo 5, imagem 3 %32
    • Put on the anti-static wristband first
    • Disconnect the port of the fan by flipping the black tab with the small blue plastic opening tool.
    • Remove the cable from the connector.
  6. HP Envy x360 m6-aq103dx CPU Fan Replacement: passo 6, imagem 1 %32 HP Envy x360 m6-aq103dx CPU Fan Replacement: passo 6, imagem 2 %32 HP Envy x360 m6-aq103dx CPU Fan Replacement: passo 6, imagem 3 %32
    • Peel back a little bit of the grey tape connected to the round cable with the big blue opening tool.
    • Using your fingers, peel the tape off of the body of the computer.
    • Peel slowly to avoid separating the adhesive.
  7. HP Envy x360 m6-aq103dx CPU Fan Replacement: passo 7, imagem 1 %32 HP Envy x360 m6-aq103dx CPU Fan Replacement: passo 7, imagem 2 %32
    • Remove the black cable from the fan by unclicking it from the plastic body of the fan with your fingers and move it out of the area.
    • There will be clicking sounds when the black cable is removed.
  8. HP Envy x360 m6-aq103dx CPU Fan Replacement: passo 8, imagem 1 %32 HP Envy x360 m6-aq103dx CPU Fan Replacement: passo 8, imagem 2 %32 HP Envy x360 m6-aq103dx CPU Fan Replacement: passo 8, imagem 3 %32
    • Disconnect the port with the red yellow and blue wires by dislodging the wires with your fingers.
  9. HP Envy x360 m6-aq103dx CPU Fan Replacement: passo 9, imagem 1 %32
    • Remove the two 4.5mm Phillips #1 screws.
  10. HP Envy x360 m6-aq103dx CPU Fan Replacement: passo 10, imagem 1 %32
    • Loosen the four black screws by the curved heat sink with a Phillips head 1 screwdriver.
    • These screws do not come off.
  11. HP Envy x360 m6-aq103dx CPU Fan Replacement: passo 11, imagem 1 %32 HP Envy x360 m6-aq103dx CPU Fan Replacement: passo 11, imagem 2 %32 HP Envy x360 m6-aq103dx CPU Fan Replacement: passo 11, imagem 3 %32
    • Lift the CPU fan out with your hand.
Conclusão
4 outras pessoas executaram este guia.
Jordan Eremeyeff
Membro desde: 10/01/17
597 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S4-G3, Livingston Fall 2017 Membro de Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
Membros da 4
Autoria de 9 guias
3 comentários
Step 5-7 can be bypassed I didn’t need to do it
diego.montenegro23 - Responder
My first home repair so far. Really easy to follow guide. Great job!
Caleb Robinson - Responder
Purchased tools and did the steps, no issues. worth the tools to use later. Worked in iT anyways.
Roy Rodgers - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 18
Duração total: 4,470
