Ir para o conteúdo principal
HP Envy x360 m6-aq103dx Battery Replacement
O que você precisa
  1. HP Envy x360 m6-aq103dx Battery Replacement, Bottom Cover: passo 1, imagem 1 %32 HP Envy x360 m6-aq103dx Battery Replacement, Bottom Cover: passo 1, imagem 2 %32 HP Envy x360 m6-aq103dx Battery Replacement, Bottom Cover: passo 1, imagem 3 %32
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Battery Replacement: passo 2, imagem 1 %32
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Battery Replacement: passo 3, imagem 1 %32
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Battery Replacement: passo 4, imagem 1 %32 HP Envy x360 m6-aq103dx Battery Replacement: passo 4, imagem 2 %32 HP Envy x360 m6-aq103dx Battery Replacement: passo 4, imagem 3 %32
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx Battery Replacement, Battery: passo 5, imagem 1 %32 HP Envy x360 m6-aq103dx Battery Replacement, Battery: passo 5, imagem 2 %32
    • Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
  6. HP Envy x360 m6-aq103dx Battery Replacement: passo 6, imagem 1 %32 HP Envy x360 m6-aq103dx Battery Replacement: passo 6, imagem 2 %32 HP Envy x360 m6-aq103dx Battery Replacement: passo 6, imagem 3 %32
    • Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
    • Lift up the port with the tool.
  7. HP Envy x360 m6-aq103dx Battery Replacement: passo 7, imagem 1 %32 HP Envy x360 m6-aq103dx Battery Replacement: passo 7, imagem 2 %32 HP Envy x360 m6-aq103dx Battery Replacement: passo 7, imagem 3 %32
    • Lift the battery out of the laptop with your hands.
Conclusão
5 outras pessoas executaram este guia.
Sarah Samora
Membro desde: 10/02/17
777 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S4-G3, Livingston Fall 2017 Membro de Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 29
Duração total: 7,378
