Introdução
The power port is essential in recharging the computer's battery. This guide will explain how to properly remove and replace the power port component of the computer.
O que você precisa
Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
Use a JIS #1 screwdriver to remove the 4.7mm screws from the indicated positions.
Use the JIS #1 screwdriver to remove the 7.7mm screws from the indicated positions.
Use the JIS #1 screwdriver to remove the 4.4mm screws from the indicated positions.
Flip the indicated colored latches with iFixit Opening Tools, then use tweezers to release the cables attached to the motherboard by gently pulling backward.
Use the pointed tweezer to release the plug-in connectors my gently gripping the plug and pulling backwards.
