Ir para o conteúdo principal
HP Envy x360 m6-aq005dx Battery Replacement
O que você precisa
  1. HP Envy x360 m6-aq005dx Battery Replacement, Back Panel: passo 1, imagem 1 %32 HP Envy x360 m6-aq005dx Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
  2. HP Envy x360 m6-aq005dx Battery Replacement: passo 2, imagem 1 %32 HP Envy x360 m6-aq005dx Battery Replacement: passo 2, imagem 2 %32 HP Envy x360 m6-aq005dx Battery Replacement: passo 2, imagem 3 %32
    • Use a Torx T5 screwdriver to remove the six 5.1 mm screws.
    • Use a JIS #1 screwdriver to remove the two 7.2mm screws.
  3. HP Envy x360 m6-aq005dx Battery Replacement: passo 3, imagem 1 %32
    • Use a plastic opening tool to pry open the case. Go slowly around the edge. You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
  4. HP Envy x360 m6-aq005dx Battery Replacement, Battery: passo 4, imagem 1 %32 HP Envy x360 m6-aq005dx Battery Replacement, Battery: passo 4, imagem 2 %32
    • Use a JIS #1 screwdriver to remove the six 4.7 mm screws.
  5. HP Envy x360 m6-aq005dx Battery Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Battery might cause a small electric shock.
    • Use tweezers to disconnect the battery from the motherboard.
Conclusão
7 outras pessoas executaram este guia.
Matthew Martin
Membro desde: 10/10/17
718 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S13-G17, Cagle Fall 2017 Membro de USF Tampa, Team S13-G17, Cagle Fall 2017
USFT-CAGLE-F17S13G17
Membros da 4
Autoria de 7 guias
3 comentários
Step 3 was the toughest!!! Case was difficult to separate.
Bo Hagen - Responder
Thank you!!!! This made it sooooo easy to replace my battery!
Michelle Kuhlmann - Responder
Excellent guide, many thanks for posting it.
stephenm.race - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 68
Duração total: 15,745
