Introdução
If you want to change out your for your HP Envy x360 m Convertible (Model 15m-cn0012dx), use this guide to replace the hard drive.
If you are running low on space, updating a hard drive with a larger drive can give you more space, and could also speed up your computer.
O que você precisa
Set the laptop face down.
Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
Uma outra pessoa concluiu este guia.
