Ir para o conteúdo principal
HP Envy x360 15m-cn0012dx Daughterboard Replacement
O que você precisa
  1. HP Envy x360 15m-cn0012dx Daughterboard Replacement, Daughterboard: passo 1, imagem 1 %32 HP Envy x360 15m-cn0012dx Daughterboard Replacement, Daughterboard: passo 1, imagem 2 %32
    • Make sure the computer is turned off, and remove all cables.
    • Set the laptop face down.
    • Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
    • Peel slowly to avoid tearing the rubber covers.
  2. HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 2, imagem 1 %32 HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 2, imagem 2 %32 HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 2, imagem 3 %32
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
  3. HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 3, imagem 1 %32 HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 3, imagem 2 %32 HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 3, imagem 3 %32
    • Pry open the back cover using the iFixit Opening Tool.
    • While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
    • Once all the corners are slightly lifted, carefully pop off the back cover.
  4. HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 4, imagem 1 %32 HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 4, imagem 2 %32 HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 4, imagem 3 %32
    • Use the iFixit opening tool to unlatch the ZIF connector with the cable labelled 'SD' from the daughterboard.
    • Slide out the interconnect ribbon cable.
  5. HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 5, imagem 1 %32 HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 5, imagem 2 %32 HP Envy x360 15m-cn0012dx Daughterboard Replacement: passo 5, imagem 3 %32
    • Using a Phillips #0 screwdriver, remove the two 4mm screws on holding down the SD card daughterboard.
    • Remove the SD card daughterboard.
Conclusão
Uma outra pessoa concluiu este guia.
Grace Daleki
Membro desde: 02/04/20
475 Reputação
Autoria de 3 guias
Equipe
UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 Membro de UW Stout, Team S1-G3, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G3
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 711
