Ir para o conteúdo principal
HP Envy x360 15m-bq121dx Cooling Fan Replacement
O que você precisa
  1. HP Envy x360 15m-bq121dx Cooling Fan Replacement, Cooling Fan: passo 1, imagem 1 %32 HP Envy x360 15m-bq121dx Cooling Fan Replacement, Cooling Fan: passo 1, imagem 2 %32
    • Be sure the computer is powered off.
    • Remove the rubber strip along the top of the backside of the computer.
    • On the back panel of the device, remove the four (4) 2.5 mm screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq121dx Cooling Fan Replacement: passo 2, imagem 1 %32 HP Envy x360 15m-bq121dx Cooling Fan Replacement: passo 2, imagem 2 %32 HP Envy x360 15m-bq121dx Cooling Fan Replacement: passo 2, imagem 3 %32
    • To remove the back cover, use the spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
    • Be sure to not damage any of the electronics on the inside.
  3. HP Envy x360 15m-bq121dx Cooling Fan Replacement: passo 3, imagem 1 %32
    • Use the Philips #0 screwdriver to remove seven 2 mm screws from battery.
  4. HP Envy x360 15m-bq121dx Cooling Fan Replacement: passo 4, imagem 1 %32
    • Lift and pull the front of the battery up and out away from the connector to remove.
  5. HP Envy x360 15m-bq121dx Cooling Fan Replacement: passo 5, imagem 1 %32 HP Envy x360 15m-bq121dx Cooling Fan Replacement: passo 5, imagem 2 %32
    • Using a Philips #0 screwdriver, remove the three 2 mm screws located around the cooling fan as shown in this picture.
    • The fan may have sharp edges so be careful upon removal.
  6. HP Envy x360 15m-bq121dx Cooling Fan Replacement: passo 6, imagem 1 %32 HP Envy x360 15m-bq121dx Cooling Fan Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the connector clip with the tweezers.
  7. HP Envy x360 15m-bq121dx Cooling Fan Replacement: passo 7, imagem 1 %32
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
  8. HP Envy x360 15m-bq121dx Cooling Fan Replacement: passo 8, imagem 1 %32 HP Envy x360 15m-bq121dx Cooling Fan Replacement: passo 8, imagem 2 %32
    • Remove the cooling fan.
Conclusão
Fabien Perez
Membro desde: 02/13/20
157 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 39
Duração total: 1,914
