Introdução
Use this guide to replace the motherboard for the HP Envy x360 15m-bp112dx. The motherboard is what all components of a laptop are connected to. The motherboard also allows for these components to communicate with each other. It may need to be replaced if error codes appear on a laptop specific to the motherboard, the display is not working, or the blue screen of death appears on the laptop.
O que você precisa
Start by facing the device upside down with the hinge facing away from you.
Remove the seven 1 mm Phillips screws.
Carefully peel back the tape connecting the heat sink to the fan assembly.
Loosen the four 1 mm Phillips screws retaining the fan assembly.
Remove the three 2 mm Phillips screws.
Remove the two 5 mm Phillips screws from the first speaker.
Carefully peel back the tape.
