Ir para o conteúdo principal
HP Envy x360 15m-bp112dx Motherboard Replacement
O que você precisa
  1. HP Envy x360 15m-bp112dx Motherboard Replacement, Hard Drive: passo 1, imagem 1 %32
    • Power off the laptop before starting the disassembly.
    • Start by facing the device upside down with the hinge facing away from you.
    • Remove the seven 1 mm Phillips screws.
  2. HP Envy x360 15m-bp112dx Motherboard Replacement: passo 2, imagem 1 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 2, imagem 2 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 2, imagem 3 %32
    • Use an opening tool to pry the back panel by pushing the bottom cover upwards.
    • Place the bottom cover away from the laptop.
  3. HP Envy x360 15m-bp112dx Motherboard Replacement: passo 3, imagem 1 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 3, imagem 2 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 3, imagem 3 %32
    • Carefully remove the sata ribbon cable from the hard drive, pulling it out horizontally.
    • To avoid injury, ensure that you disconnect the battery prior to removing any of the cables in the laptop.
  4. HP Envy x360 15m-bp112dx Motherboard Replacement: passo 4, imagem 1 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 4, imagem 2 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 4, imagem 3 %32
    • Remove the hard drive by pulling it out vertically.
    • Remove the plastic casing around the hard drive by peeling it back.
  5. HP Envy x360 15m-bp112dx Motherboard Replacement: passo 5, imagem 1 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 5, imagem 2 %32
    • Disconnect the ribbon cable by pulling it away horizontally from the hard drive.
  6. HP Envy x360 15m-bp112dx Motherboard Replacement, Fan: passo 6, imagem 1 %32 HP Envy x360 15m-bp112dx Motherboard Replacement, Fan: passo 6, imagem 2 %32
    • Carefully peel back the tape connecting the heat sink to the fan assembly.
    • Loosen the four 1 mm Phillips screws retaining the fan assembly.
    • Remove the three 2 mm Phillips screws.
  7. HP Envy x360 15m-bp112dx Motherboard Replacement: passo 7, imagem 1 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 7, imagem 2 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 7, imagem 3 %32
    • Unplug the thin cable connected to the fan, pulling horizontally.
    • Carefully peel back the connected tape.
  8. HP Envy x360 15m-bp112dx Motherboard Replacement: passo 8, imagem 1 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 8, imagem 2 %32
    • Carefully remove the fan assembly by pulling on it upwards.
    • When reassembling, ensure that you clean off and replace the thermal paste on the fan assembly.
  9. HP Envy x360 15m-bp112dx Motherboard Replacement, Motherboard: passo 9, imagem 1 %32 HP Envy x360 15m-bp112dx Motherboard Replacement, Motherboard: passo 9, imagem 2 %32 HP Envy x360 15m-bp112dx Motherboard Replacement, Motherboard: passo 9, imagem 3 %32
    • Remove the two 5 mm Phillips screws from the first speaker.
    • Carefully peel back the tape.
  10. HP Envy x360 15m-bp112dx Motherboard Replacement: passo 10, imagem 1 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 10, imagem 2 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 10, imagem 3 %32
    • Open the tab connected to the right speaker cord, prying it with a plastic opening tool upwards.
    • Pull out the speaker cord horizontally.
  11. HP Envy x360 15m-bp112dx Motherboard Replacement: passo 11, imagem 1 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 11, imagem 2 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 11, imagem 3 %32
    • Remove the thin cable from the speaker, pulling it out horizontally.
  12. HP Envy x360 15m-bp112dx Motherboard Replacement: passo 12, imagem 1 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 12, imagem 2 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 12, imagem 3 %32
    • Remove the right speaker, pulling upward carefully.
    • While pulling on the speaker, unwind the cord around the plastic clips to free the speaker and place it to the side.
  13. HP Envy x360 15m-bp112dx Motherboard Replacement: passo 13, imagem 1 %32
    • Remove the twelve 2.5 mm Phillips screws.
  14. HP Envy x360 15m-bp112dx Motherboard Replacement: passo 14, imagem 1 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 14, imagem 2 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 14, imagem 3 %32
    • Unclip the ribbon cable using a plastic opening tool to flip up the black ZIF connector locking flap.
    • Remove the ribbon cable by pulling it out horizontally.
  15. HP Envy x360 15m-bp112dx Motherboard Replacement: passo 15, imagem 1 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 15, imagem 2 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 15, imagem 3 %32
    • Unclip the second ribbon cable using a plastic opening tool to flip the black ZIF connector locking flap up.
  16. HP Envy x360 15m-bp112dx Motherboard Replacement: passo 16, imagem 1 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 16, imagem 2 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 16, imagem 3 %32
    • Unclip the third ribbon cable using a plastic opening tool to flip up the black ZIF connector locking flap.
  17. HP Envy x360 15m-bp112dx Motherboard Replacement: passo 17, imagem 1 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 17, imagem 2 %32
    • Remove the thin cable carefully by pulling out horizontally in line with its slot.
  18. HP Envy x360 15m-bp112dx Motherboard Replacement: passo 18, imagem 1 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 18, imagem 2 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 18, imagem 3 %32
    • Unclip the fourth ribbon cable using a plastic opening tool to flip up the black ZIF connector.
  19. HP Envy x360 15m-bp112dx Motherboard Replacement: passo 19, imagem 1 %32 HP Envy x360 15m-bp112dx Motherboard Replacement: passo 19, imagem 2 %32
    • Carefully remove the motherboard by pulling upwards on it.
Conclusão
Cameron Anderson
Membro desde: 03/20/23
289 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 6-2, Botvin Spring 2023 Membro de UMass Dartmouth, Team 6-2, Botvin Spring 2023
UMASSD-BOTVIN-S23S6G2
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 23
Duração total: 247
