Ir para o conteúdo principal
HP Envy x360 15m-bp112dx Hard Drive Replacement
O que você precisa
  1. HP Envy x360 15m-bp112dx Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Power off the laptop before starting the disassembly.
    • Start by facing the device upside down with the hinge facing away from you.
    • Remove the seven 1 mm Phillips screws.
  2. HP Envy x360 15m-bp112dx Hard Drive Replacement: passo 2, imagem 1 %32 HP Envy x360 15m-bp112dx Hard Drive Replacement: passo 2, imagem 2 %32 HP Envy x360 15m-bp112dx Hard Drive Replacement: passo 2, imagem 3 %32
    • Use an opening tool to pry the back panel by pushing the bottom cover upwards.
    • Place the bottom cover away from the laptop.
  3. HP Envy x360 15m-bp112dx Hard Drive Replacement: passo 3, imagem 1 %32 HP Envy x360 15m-bp112dx Hard Drive Replacement: passo 3, imagem 2 %32 HP Envy x360 15m-bp112dx Hard Drive Replacement: passo 3, imagem 3 %32
    • Carefully remove the sata ribbon cable from the hard drive, pulling it out horizontally.
    • To avoid injury, ensure that you disconnect the battery prior to removing any of the cables in the laptop.
  4. HP Envy x360 15m-bp112dx Hard Drive Replacement: passo 4, imagem 1 %32 HP Envy x360 15m-bp112dx Hard Drive Replacement: passo 4, imagem 2 %32 HP Envy x360 15m-bp112dx Hard Drive Replacement: passo 4, imagem 3 %32
    • Remove the hard drive by pulling it out vertically.
    • Remove the plastic casing around the hard drive by peeling it back.
  5. HP Envy x360 15m-bp112dx Hard Drive Replacement: passo 5, imagem 1 %32 HP Envy x360 15m-bp112dx Hard Drive Replacement: passo 5, imagem 2 %32
    • Disconnect the ribbon cable by pulling it away horizontally from the hard drive.
Conclusão
Mohamed Kozamel
Membro desde: 03/20/23
121 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 6-2, Botvin Spring 2023 Membro de UMass Dartmouth, Team 6-2, Botvin Spring 2023
UMASSD-BOTVIN-S23S6G2
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 259
