Ir para o conteúdo principal
HP Envy x360 15m-bp112dx Fan Replacement
O que você precisa
  1. HP Envy x360 15m-bp112dx Fan Replacement, Hard Drive: passo 1, imagem 1 %32
    • Power off the laptop before starting the disassembly.
    • Start by facing the device upside down with the hinge facing away from you.
    • Remove the seven 1 mm Phillips screws.
  2. HP Envy x360 15m-bp112dx Fan Replacement: passo 2, imagem 1 %32 HP Envy x360 15m-bp112dx Fan Replacement: passo 2, imagem 2 %32 HP Envy x360 15m-bp112dx Fan Replacement: passo 2, imagem 3 %32
    • Use an opening tool to pry the back panel by pushing the bottom cover upwards.
    • Place the bottom cover away from the laptop.
  3. HP Envy x360 15m-bp112dx Fan Replacement: passo 3, imagem 1 %32 HP Envy x360 15m-bp112dx Fan Replacement: passo 3, imagem 2 %32 HP Envy x360 15m-bp112dx Fan Replacement: passo 3, imagem 3 %32
    • Carefully remove the sata ribbon cable from the hard drive, pulling it out horizontally.
    • To avoid injury, ensure that you disconnect the battery prior to removing any of the cables in the laptop.
  4. HP Envy x360 15m-bp112dx Fan Replacement: passo 4, imagem 1 %32 HP Envy x360 15m-bp112dx Fan Replacement: passo 4, imagem 2 %32 HP Envy x360 15m-bp112dx Fan Replacement: passo 4, imagem 3 %32
    • Remove the hard drive by pulling it out vertically.
    • Remove the plastic casing around the hard drive by peeling it back.
  5. HP Envy x360 15m-bp112dx Fan Replacement: passo 5, imagem 1 %32 HP Envy x360 15m-bp112dx Fan Replacement: passo 5, imagem 2 %32
    • Disconnect the ribbon cable by pulling it away horizontally from the hard drive.
  6. HP Envy x360 15m-bp112dx Fan Replacement, Fan: passo 6, imagem 1 %32 HP Envy x360 15m-bp112dx Fan Replacement, Fan: passo 6, imagem 2 %32
    • Carefully peel back the tape connecting the heat sink to the fan assembly.
    • Loosen the four 1 mm Phillips screws retaining the fan assembly.
    • Remove the three 2 mm Phillips screws.
  7. HP Envy x360 15m-bp112dx Fan Replacement: passo 7, imagem 1 %32 HP Envy x360 15m-bp112dx Fan Replacement: passo 7, imagem 2 %32 HP Envy x360 15m-bp112dx Fan Replacement: passo 7, imagem 3 %32
    • Unplug the thin cable connected to the fan, pulling horizontally.
    • Carefully peel back the connected tape.
  8. HP Envy x360 15m-bp112dx Fan Replacement: passo 8, imagem 1 %32 HP Envy x360 15m-bp112dx Fan Replacement: passo 8, imagem 2 %32
    • Carefully remove the fan assembly by pulling on it upwards.
    • When reassembling, ensure that you clean off and replace the thermal paste on the fan assembly.
Conclusão
Cameron Anderson
Membro desde: 03/20/23
289 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 6-2, Botvin Spring 2023 Membro de UMass Dartmouth, Team 6-2, Botvin Spring 2023
UMASSD-BOTVIN-S23S6G2
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 137
