Introdução
This guide will assist in locating, removing, and replacing the hard drive of your HP Envy x360 15m-bp111dx. You may need to utilize this guide if your laptop is displaying a warning message concerning the hard drive or the computer does not boot up.
Be sure that your laptop is powered off, you're disconnected from the power adapter, and that the components have cooled before beginning this replacement.
For more troubleshooting information for the Hard Drive, follow the instructions on the troubleshooting page.
O que você precisa
Remove the rubber feet to access the screws.
Using a Phillips #0 screwdriver, remove the four 7 mm screws.
Using a T5 Torx screwdriver, remove the three 5 mm screws.
Use a Phillips screwdriver to remove the seven 4 mm screws securing the battery.
The hard drive bay is located in the lower left corner of the computer.
The hard drive will be covered by a black rubber sheath which can be removed by simply pulling it off of the hard drive (not pictured).
