Ir para o conteúdo principal
HP Envy x360 15m-bp111dx Charging Port Replacement
O que você precisa
  1. HP Envy x360 15m-bp111dx Charging Port Replacement, Back Panel: passo 1, imagem 1 %32 HP Envy x360 15m-bp111dx Charging Port Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Charging Port Replacement: passo 2, imagem 1 %32 HP Envy x360 15m-bp111dx Charging Port Replacement: passo 2, imagem 2 %32 HP Envy x360 15m-bp111dx Charging Port Replacement: passo 2, imagem 3 %32
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Charging Port Replacement, Charging Port: passo 3, imagem 1 %32 HP Envy x360 15m-bp111dx Charging Port Replacement, Charging Port: passo 3, imagem 2 %32 HP Envy x360 15m-bp111dx Charging Port Replacement, Charging Port: passo 3, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the two M2x3.1 screws that secure the speaker in place.
    • Lift and move the speaker to the side.
    • Do not pull too hard on the speaker. It is connected by thin wires that run under the motherboard.
  4. HP Envy x360 15m-bp111dx Charging Port Replacement: passo 4, imagem 1 %32 HP Envy x360 15m-bp111dx Charging Port Replacement: passo 4, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove remove three M2.5x4 screws that secure the hinge.
  5. HP Envy x360 15m-bp111dx Charging Port Replacement: passo 5, imagem 1 %32
    • Use the opening tool to raise the hinge.
    • Then lift the hinge by hand to provide enough clearance to remove the charging port.
    • Be careful when lifting the hinge. The back can be bent and damaged if raised too far.
  6. HP Envy x360 15m-bp111dx Charging Port Replacement: passo 6, imagem 1 %32 HP Envy x360 15m-bp111dx Charging Port Replacement: passo 6, imagem 2 %32
    • Gently slide the charging port connector out of the port, and lift it above the hinge.
  7. HP Envy x360 15m-bp111dx Charging Port Replacement: passo 7, imagem 1 %32 HP Envy x360 15m-bp111dx Charging Port Replacement: passo 7, imagem 2 %32 HP Envy x360 15m-bp111dx Charging Port Replacement: passo 7, imagem 3 %32
    • Grasp the sliding connector on the motherboard and remove it from the socket.
  8. HP Envy x360 15m-bp111dx Charging Port Replacement: passo 8, imagem 1 %32
    • Remove the charging port.
Conclusão
Uma outra pessoa concluiu este guia.
Tori Luongo
Membro desde: 02/22/22
268 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 2-2, Hunter Spring 2022 Membro de Clemson, Team 2-2, Hunter Spring 2022
CLEM-HUNTER-S22S2G2
Membros da 5
Autoria de 6 guias
Um comentário
What is a typical charge for a technician to replace the charging port and what should a typical charging port cost?
Robert Ford - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 34
Duração total: 583
