Ir para o conteúdo principal
HP Envy x360 15m-bp111dx Battery Replacement
O que você precisa
  1. HP Envy x360 15m-bp111dx Battery Replacement, Back Panel: passo 1, imagem 1 %32 HP Envy x360 15m-bp111dx Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Battery Replacement: passo 2, imagem 1 %32 HP Envy x360 15m-bp111dx Battery Replacement: passo 2, imagem 2 %32 HP Envy x360 15m-bp111dx Battery Replacement: passo 2, imagem 3 %32
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Battery Replacement, Battery: passo 3, imagem 1 %32 HP Envy x360 15m-bp111dx Battery Replacement, Battery: passo 3, imagem 2 %32
    • Use a Phillips screwdriver to remove the seven 4 mm screws securing the battery.
  4. HP Envy x360 15m-bp111dx Battery Replacement: passo 4, imagem 1 %32 HP Envy x360 15m-bp111dx Battery Replacement: passo 4, imagem 2 %32 HP Envy x360 15m-bp111dx Battery Replacement: passo 4, imagem 3 %32
    • Carefully lift the battery, and pull it towards you to remove it.
Conclusão
Uma outra pessoa concluiu este guia.
Tori Luongo
Membro desde: 02/22/22
268 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 2-2, Hunter Spring 2022 Membro de Clemson, Team 2-2, Hunter Spring 2022
CLEM-HUNTER-S22S2G2
Membros da 5
Autoria de 6 guias
Um comentário
This website has been very helpful but you only show how to remove a battery. You've left out the replace part of the replacement. Would really help. Thanks!
book mite - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 46
Duração total: 685
