Ir para o conteúdo principal
HP Envy x360 15-u473cl Touch Screen Replacement
O que você precisa
  1. HP Envy x360 15-u473cl Touch Screen Replacement, Touch Screen: passo 1, imagem 1 %32 HP Envy x360 15-u473cl Touch Screen Replacement, Touch Screen: passo 1, imagem 2 %32
    • Remove the two anti-tamper covers from the bottom corners of the screen using the spudger which will reveal two screws.
    • Remove the two 3mm screws using the J00 Phillips screwdriver.
  2. HP Envy x360 15-u473cl Touch Screen Replacement: passo 2, imagem 1 %32
    • Move the plastic opening tool along the seem while prying up to separate the display housing from the laptop cover.
    • If the touch screen housing is cracked, it may splinter or shatter while separating.
  3. HP Envy x360 15-u473cl Touch Screen Replacement: passo 3, imagem 1 %32
    • Remove the four 3mm screws using the Phillips #00 screwdriver.
  4. HP Envy x360 15-u473cl Touch Screen Replacement: passo 4, imagem 1 %32 HP Envy x360 15-u473cl Touch Screen Replacement: passo 4, imagem 2 %32
    • Lift the white UPC tape using the spudger, and disconnect the the golden connector from the screen.
    • There may be a piece of black tape connecting a bundle of wires to the screen. Remove the piece of black tape if present.
    • Remove the touch screen.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 39
Duração total: 12,821
