Introdução
The fan can become jammed with debris or stop working over time, causing the device to overheat.
O que você precisa
Pry off the 2 rear rubber pads (closest to the laptop hinge) using the plastic opening tool to reveal two screws.
Remove the 2 anti-tamper proof covers using the spudger to reveal two screws.
Remove the three 4mm screws using the Phillips #0 screwdriver from the device fan.
Uma outra pessoa concluiu este guia.
