Ir para o conteúdo principal
HP Envy x360 15-bp143cl Screen Replacement
O que você precisa
  1. HP Envy x360 15-bp143cl Screen Replacement, Screen: passo 1, imagem 1 %32
    • Use a suction handle to pull the screen display out of the screen casing.
    • If the screen is difficult to remove, use an opening tool to pry the sides of screen from the screen casing.
  2. HP Envy x360 15-bp143cl Screen Replacement: passo 2, imagem 1 %32 HP Envy x360 15-bp143cl Screen Replacement: passo 2, imagem 2 %32
    • Lift the screen display from the screen casing, hinging it from the top edge to expose the back of the panel.
    • Do not separate the display from the casing completely, as there are still cable connections holding it in place.
  3. HP Envy x360 15-bp143cl Screen Replacement: passo 3, imagem 1 %32 HP Envy x360 15-bp143cl Screen Replacement: passo 3, imagem 2 %32
    • Detach the connecting cable between the laptop and the display screen.
    • Remove the display screen.
Conclusão
3 outras pessoas executaram este guia.
Spencer Berkins
Membro desde: 10/10/19
577 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S12-G3, Regan Fall 2019 Membro de Cal Poly, Team S12-G3, Regan Fall 2019
CPSU-REGAN-F19S12G3
Membros da 3
Autoria de 6 guias
Um comentário
Thank you for this great guide, been very useful knowing how to remove the screen from th housing! However; I'm looking to replace not the screen but the 'screen housing' as the plastic bracket that the hinges screw into (three round flat screws you can see for each hinge) has torn. Very bad design IMHO. The entire screw/bolt has just torn free (all three) on the right hinge. Seeing as the plastic bracket is glued to the metal casing it is irreparable…
Anybody know where I can get the replacement (my HP Envy has a metal/aluminium housing in silver colour).
Kind regards,
Adrian
Adrian Munro - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 29
Últimos 30 dias: 117
Duração total: 4,289
