Ir para o conteúdo principal
HP Envy x360 15-bp143cl SSD Replacement
O que você precisa
  1. HP Envy x360 15-bp143cl SSD Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl SSD Replacement: passo 2, imagem 1 %32
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl SSD Replacement: passo 3, imagem 1 %32
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl SSD Replacement: passo 4, imagem 1 %32
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl SSD Replacement: passo 5, imagem 1 %32 HP Envy x360 15-bp143cl SSD Replacement: passo 5, imagem 2 %32
    • Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
  6. HP Envy x360 15-bp143cl SSD Replacement: passo 6, imagem 1 %32
    • Pull the battery from the connecting port and lift to remove it from the laptop.
  7. HP Envy x360 15-bp143cl SSD Replacement, SSD: passo 7, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the single 4 mm screw securing the SSD.
  8. HP Envy x360 15-bp143cl SSD Replacement: passo 8, imagem 1 %32
    • Pull the SSD directly out its port.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 50
Ao todo: 4,680
