Ir para o conteúdo principal
HP Envy x360 15-bp143cl Hard Drive Replacement
O que você precisa
  1. HP Envy x360 15-bp143cl Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl Hard Drive Replacement: passo 2, imagem 1 %32
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl Hard Drive Replacement: passo 3, imagem 1 %32
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl Hard Drive Replacement: passo 4, imagem 1 %32
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl Hard Drive Replacement: passo 5, imagem 1 %32 HP Envy x360 15-bp143cl Hard Drive Replacement: passo 5, imagem 2 %32
    • Lift the black tab securing the hard drive connecting cable to the laptop to remove the cable.
  6. HP Envy x360 15-bp143cl Hard Drive Replacement: passo 6, imagem 1 %32
    • Lift the hard drive from its slot.
    • If the hard drive is attached using adhesive, use an opening tool to pry it from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Spencer Berkins
Membro desde: 10/10/19
577 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S12-G3, Regan Fall 2019 Membro de Cal Poly, Team S12-G3, Regan Fall 2019
CPSU-REGAN-F19S12G3
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 23
Duração total: 1,149
