Ir para o conteúdo principal
HP Envy x2 13-j002dx Battery Replacement
O que você precisa
  1. HP Envy x2 13-j002dx Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove five 4mm Phillips #0 screws securing the lower case to the HP Envy x2 13-j002dx.
  2. HP Envy x2 13-j002dx Battery Replacement: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the two 3.5 mm screws from the bottom of the device—one on each side of the keyboard dock.
  3. HP Envy x2 13-j002dx Battery Replacement: passo 3, imagem 1 %32
    • Use a pair of tweezers to remove the screw covers on the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws.
  4. HP Envy x2 13-j002dx Battery Replacement: passo 4, imagem 1 %32 HP Envy x2 13-j002dx Battery Replacement: passo 4, imagem 2 %32
    • Use an opening pick to remove the plastic cover above the back stand.
    • Pry the cover off.
    • Use a Phillips #0 screwdriver to remove the four 4 mm screws.
  5. HP Envy x2 13-j002dx Battery Replacement: passo 5, imagem 1 %32
    • Use an opening pick and a prying tool, and go around the device to remove the back cover from the rest of the assembly.
  6. HP Envy x2 13-j002dx Battery Replacement: passo 6, imagem 1 %32
    • Unplug the battery from the motherboard.
  7. HP Envy x2 13-j002dx Battery Replacement: passo 7, imagem 1 %32 HP Envy x2 13-j002dx Battery Replacement: passo 7, imagem 2 %32
    • Carefully pull up on the battery connector from the speaker.
    • Use a pair of tweezers and remove the taped down wire for the speaker.
    • Use a Phillips #00 screwdriver to remove the seven 3mm screws around the battery.
  8. HP Envy x2 13-j002dx Battery Replacement: passo 8, imagem 1 %32
    • Carefully lift up and remove the battery.
Conclusão
5 outras pessoas executaram este guia.
Um comentário
For step 2, when I was taking the screws out, they were held in by the magnets that were on either side of them making it difficult to remove. I ended up having to use another magnet to get them out.
Reed Jochimsen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 1,888
