Introdução
In this guide we will be opening up the HP Envy x2 13-j002dx and replacing the battery. This is an easier repair that can be done by just about anyone. The only screw driver required is a Philips #0 and a Philips #00 screw drivers. You will also need a pair of tweezers and a set of opening picks.
O que você precisa
Remove five 4mm Phillips #0 screws securing the lower case to the HP Envy x2 13-j002dx.
5 outras pessoas executaram este guia.
Um comentário
For step 2, when I was taking the screws out, they were held in by the magnets that were on either side of them making it difficult to remove. I ended up having to use another magnet to get them out.
