Ir para o conteúdo principal
HP Envy m6-p114dx Speaker Replacement
O que você precisa
  1. HP Envy m6-p114dx Speaker Replacement, Back Panel: passo 1, imagem 1 %32 HP Envy m6-p114dx Speaker Replacement, Back Panel: passo 1, imagem 2 %32 HP Envy m6-p114dx Speaker Replacement, Back Panel: passo 1, imagem 3 %32
    • Power the device off, unplug it, and ground yourself.
  2. HP Envy m6-p114dx Speaker Replacement: passo 2, imagem 1 %32
    • Remove the twelve screws in the back case using a Phillips #1 screwdriver.
  3. HP Envy m6-p114dx Speaker Replacement: passo 3, imagem 1 %32
    • Carefully wedge an iFixit opening tool under the cover and slide it alongside the case to ensure that all clips are un-clipped.
  4. HP Envy m6-p114dx Speaker Replacement, Speaker: passo 4, imagem 1 %32 HP Envy m6-p114dx Speaker Replacement, Speaker: passo 4, imagem 2 %32 HP Envy m6-p114dx Speaker Replacement, Speaker: passo 4, imagem 3 %32
    • Unscrew the two screws that have a pink spacer below them with a Phillips #0 screwdriver.
    • Lift directly up to remove the main speaker.
    • Gently pull the wire out of the plastic track that it's set in.
  5. HP Envy m6-p114dx Speaker Replacement: passo 5, imagem 1 %32
    • Follow the cable around the inside of the case and remove the cable to the main board
    • Once this is removed you can fully remove the speaker!
Conclusão
Shad Padilla
Membro desde: 08/26/19
112 Reputação
Autoria de 1 guia
Equipe
Gateway, Team S1-G1, Saknee Fall 2019 Membro de Gateway, Team S1-G1, Saknee Fall 2019
GCC-SAKNEE-F19S1G1
Membros da 2
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 189
