Ir para o conteúdo principal
HP Envy m6-n010dx Hard Drive Replacement
O que você precisa
  1. HP Envy m6-n010dx Hard Drive Replacement, Battery: passo 1, imagem 1 %32 HP Envy m6-n010dx Hard Drive Replacement, Battery: passo 1, imagem 2 %32 HP Envy m6-n010dx Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. HP Envy m6-n010dx Hard Drive Replacement, Hard Drive: passo 2, imagem 1 %32
    • Remove the five marked screws found under the battery using a philips head screwdriver.
  3. HP Envy m6-n010dx Hard Drive Replacement: passo 3, imagem 1 %32 HP Envy m6-n010dx Hard Drive Replacement: passo 3, imagem 2 %32
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  4. HP Envy m6-n010dx Hard Drive Replacement: passo 4, imagem 1 %32 HP Envy m6-n010dx Hard Drive Replacement: passo 4, imagem 2 %32 HP Envy m6-n010dx Hard Drive Replacement: passo 4, imagem 3 %32
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 15
Ao todo: 1,332
