Ir para o conteúdo principal
HP Envy m6-k022dx RAM Replacement
O que você precisa
  1. HP Envy m6-k022dx RAM Replacement, Lower Case: passo 1, imagem 1 %32
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx RAM Replacement: passo 2, imagem 1 %32
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx RAM Replacement: passo 3, imagem 1 %32
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx RAM Replacement: passo 4, imagem 1 %32
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx RAM Replacement, RAM: passo 5, imagem 1 %32
    • The RAM sticks are located in the right upper corner of the laptop of the laptop.
  6. HP Envy m6-k022dx RAM Replacement: passo 6, imagem 1 %32
    • There are two clips holding each RAM stick in place; one on each side of each stick.
    • Gently pull each clips outwards, away from the RAM sticks. They will easily unclip from the RAM.
  7. HP Envy m6-k022dx RAM Replacement: passo 7, imagem 1 %32
    • Grab the top of the RAM stick and pull directly up, towards the outer edge of the laptop.
    • The RAM sticks will slide out from their slots relatively easily. They are now ready to be replaced.
Conclusão
3 outras pessoas executaram este guia.
Anthony Stubbs
Membro desde: 04/06/17
182 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S13-G6, Cagle Spring 2017 Membro de USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 1,120
